It is currently February 17th, 2019, 5:48 am
 Page 1 of 1 [ 1 post ]
Author Message
 Post subject: important.new members please read before posting.
PostPosted: September 12th, 2010, 11:01 pm
Metropolis
Welcome to the D2 Boys Club
Although there are many fine 4 wheel drive forums on the net, and some specialize in manufacturers such as Land Rover, there are few that are focused on one model or another.
The D2 Boys Club is set up with exactly that in mind. The Discovery Series 2.
The Discovery Series 2, manufactured by Land Rover between 1998 and 2004. A choice of two power units was offered to the customer as standard. These were the 2.5 litre 5 cylinder diesel newly developed by Land Rover and the 4.0 Litre (4.6 litre in the USA)V8 Petrol that evolved from earlier Rover V8s.
The D2 represented a number of innovations for Land Rover. It was the first vehicle to depart from aluminum body panels for 50 years! It was also designed to rely much more on electronics than previous models. In many cases running these vehicles requires a different approach to previous Land Rovers.
Hence a handful of members from other forums decided that it was time for a forum dedicated to the D2.
To this end you, the member, will note that questions and answers and discussions are focused around the D2 as opposed to any other model. This forum is not intended to offer any comparisons between the Discovery 2 against any other models, even in jest. Members who digress towards this tangent are likely to be politely reminded as to what the site is about. There is however an open forum within where non vehicular discussion is welcomed.
Likely members will either own a D2, have owned one, plan to own one or just have an interest in the model. Once inside you will see that there are sections dealing with servicing to modifications. As this forum develops it is hoped that more sections will be added as more input from our resourceful membership is collated.
Apart from keeping the discussions D2 focused as above we only ask that the usual forum courtesies are extended to your fellow members. Please refrain from using foul language and resist the temptation to indulge in arguments rather than reasoned differences of opinions. Also there is to be no trade advertising without the prior consent of the Forum Admin. Private ads are welcome in the relevant sections.
To make this easier then please fill in your profile :-
Location, Not your exact address but approximately!
Vehicles, What do you have. If you don't, what would you like.
Interests, Obvious really but it helps.
Above all, please dive in and ENJOY!
thank you
site admin
Offline
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
cron
