It is currently February 23rd, 2018, 1:23 am
 Page 1 of 1 [ 2 posts ]
Author Message
 Post subject: Earl's performance brake and other Hydraulic lines etc.
PostPosted: June 9th, 2017, 3:39 pm
XS spec
Hi Guys - just had some brake lines for my D2 made up by Earls performance and they have agreed to give us a 20% discount for D2BC members - just mention the D2BC when you call them to order.
They do all sorts of hydraulics stuff as well as brake lines and I've used them quite a few times in the past for brake lines/oil lines for obscure motor bikes and things.
They've always been really helpful and have the patterns on file for D2 at +40mm and now +100mm so can scale anywhere from stock to +100 with no issues. They can also do them with plated or stainless fittings and even some fairly lurid colours.
Website is www.earls.co.uk
Cheers
Duc
_________________
2000 White Gold TD5 with an identify crisis,DF sliders,TP bumper,Wildbear HD springs and lift blocks,TF +3" shocks,sorted sunroofs and headlining, FD rack,cdl,extended tbox sump,SPA temp and battery guage, black modulars on 265 muds, D44 carrier, breathers to the roof,earls+100mm lines
To be fitted:4 Pin rear diff in pegged casing,TP steering guard,wide angle rear prop,TF arches (fronts done),Safari raised air
Offline
 Profile
 Post subject: Re: Earl's performance brake and other Hydraulic lines etc.
PostPosted: June 11th, 2017, 12:55 pm
Metropolis
User avatar
Nice one! Will definitely remember.
Sent from my F8331 using Tapatalk
_________________
Paul
My Disco: http://www.thed2boysclub.co.uk/viewtopic.php?f=3&t=3378 and on Instagram: https://www.instagram.com/discovery2_life/
Offline
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
